Lessons from 5 more hours of troubleshooting...
Mike Schotte
07-14-2002 08:05:42
Hi Everyone,
Had another frustrating day while (attempting) to mow my acreage. Thought I'd share the problems and the (eventual) solution. Believe me, I wish these stories were shorter, too. (grin)
I haven't been able to get my SC to run right under load since last week, the week that I found the distributor cap of the magneto was full of an ant nest. I solved that problem, but I took the carb apart during troubleshooting before I realized that my problem was the magneto- I was afraid that I had messed up the main jet assembly on the carb.
Over the last week I rebuilt a "spare" carb to see if a transplant would solve the problem, and I charged up the battery- as I still haven't gotten my new generator to provide any charge.
Drove out to the place yesterday and installed the battery. Decided to see if the tractor would run with the original carb still on. The tractor started, but it did not run well.
Took off the original (rebuilt) carb, and swapped on the "spare" (rebuilt) carb. Added a second inline fuel filter directly in front of the carburetor. (The other filter is mounted at the tank outlet.)
The tractor was much harder to start this time, but I did get it running. Took it for a spin around the field to attempt to get the main jet adjustment set right. Tractor wasn't running well, with little power- and I barely got it back to where I started.
The tractor was then idling poorly, and started backfiring very loudly. This stopped before I could shut it off, and then the tractor ran for about two more minutes and died. Would not restart. Just for grins, I checked the plug wires to make sure I hadn't swapped a wire. Everything O.K. there.
Took the "spare" carb off and put the original carb back on. Still wouldn't start. Got to looking at my fuel filter by the carb inlet, and I could see that by the way the fuel hose was positioned, the outlet side of the filter was higher than the inlet side. I could see a large air bubble inside the filter near the outlet line, so I decided that my extra filter was causing fuel starvation to the carb.
I removed the second filter and re-installed a straight fuel line. Tractor still won't start. Doesn't even chuff- acts like there's no spark at all.
Took the plug wires off and removed the distributor cap. No ants in there this time, and it's still pretty clean. Did a little more cleaning of the contact points and wire brushed the rotor contact point. Still no start.
Removed the Champion spark plugs and replaced them with a set of Autolite 295's. The Champion plugs were only about 8 months old, but I thought I'd give the Autolites a whirl. Plugs #1 & 2 looked black, but clean. Plug #3 was pretty black & sooty, and plug #4 was even worse. Decided to ponder about this later. Still no start.
Just for grins, decided to replace the plug wires, too. The ones that were on there were still O.K., but they were about 15 years old and getting brittle. Still no change.
I then checked the magneto grounding wire to make sure the mag wasn't accidentally grounding out. Everything O.K.
Still no life from the tractor, so I pulled a couple of plugs and checked for spark. I did have spark- so the magneto was doing it's job, although you'ld never know it.
Well- I had fuel flow and I had spark, so why wasn't I getting any ignition? Even the starting fluid didn't bring any life to the tractor. I had gotten to the point where I had stopped cussing and starting praying. I was REALLY getting frustrated.
Last week I had gotten low on gas in the tractor. Due to that week's magneto problems, I never got a chance to drive into town for a fillup. Instead, I just bought 5 gallons in my gas can and poured it into the tractor. I also added 1 oz. of Sta-Bil fuel stabilizer to keep the gas from turning to varnish. All told, there was approximately 10 gallons of fuel in the tank.
Well, I started looking at the gas itself. It looked O.K., but didn't smell quite right. Didn't smell like varnish, but just smelled "weak". I pulled out my spare gascans and drained all 10 gal. out from the fuel tank. I then blew out all of the fuel lines between the tank and the carburetor and drained the carburetor bowl. Replaced the tank filter with a new one, and put about a gallon of new gas in the tank.
It still didn't want to run, but after cranking for a few minutes, I guess the last of the bad gas was finally gone. It started up and ran like an absoluted dream! Didn't have to adjust a thing on the carburetor. Loads of power and smooth idling.
I really have to wonder if someone didn't put something into the gas tank. I could tell that somebody had been out on the property, as someone had gone through one of my old Cadillacs and had left the doors open in the rain. I didn't see any other signs of mischeif or vandalism, though.
I don't know what could make the gas go that bad so quickly. Perhaps the fuel stabilizer reacted negatively with the 5 gallons of "old" gas that was already in the tank? Surely the 5 gallons of new gas should have lasted more than a week's time. But absolutely none of it was burning.
Well, it was almost sundown at this point, but I wanted to make a quick "victory lap" pass around the property with the brushog, as it had only taken my 5 hours to get to the point where I could use it...
I had hired a crew to clear some brush between me and the downhill neighbor earlier in the summer. Since then, the older gentleman has been using his smalll riding lawnmower to keep the area of our lower field (next to his front lawn) mown. He had also taken down an old fence corner and removed some dead limbs.
I decided I would mow the area near him first, as I am thankful for his help and don't want him to have to stare at my weeds any longer than necessary.
As I'm mowing, I see a 3/4" sapling growing in front of me. As I mow over it, there's a tremendous BANG. Turns out that the neighbor had cut down a tree in this location. The 3/4" sapling was growing out of a SIX INCH TRUNK that was sticking 5" up out of the ground! There was just enough underbrush to keep me from seeing the trunk before hitting it.
Well, I cautiously walked back to the tractor (which was still running beautifully) to see what had broken. Blade still attached to brushog, PTO shaft not broken (thank God)- but the shear pin was GONE!
I was so happy at seeing it was the pin that I did a little dance! About 4 months ago I had put in a new Grade 2 (butter bolt) shear pin. The pin I had removed was a Grade 8 hardened bolt that would have NEVER broken. If I had left it in, I'd probably be calling Don L. for a new PTO shaft right about now.
As it stands, though, all I've got to do is hit the hardware store for a $3.00 bolt! All that was left of the shear pin was a 1" long section in the center of the drive shaft.
The day's totals:
Time spent working on tractor - 5 hours
Time spent actually mowing - 5 minutes
Today I might go back out and actually get some work done WITH the tractor instead of ON the tractor!
-Schotte
eddie in kY
07-14-2002 19:28:11
 Re: Lessons from 5 more hours of troubleshooting... in reply to Mike Schotte, 07-14-2002 08:05:42
I know about the dance all to well. And you just dont even care who sees you either at the time.
Don L. @ Rusty Acre
07-14-2002 09:19:50
What a day you had, for sure. A person can never do too many of those happy dances, you talked about!!! Keep clickin your heels! Don L.
