Where to place control valve on DB 995
James
07-13-2002 17:19:18
Any suggestions on where to mount my 2 spool loader control valve on a David Brown 995. I would like to keep it on the tractor rather than mount it on the loader itself.(the loader is easy-on, so the valve is used to mount it. also the loader is so far forward, I hate to mount to it.)
Elmer
07-13-2002 18:07:53
 Re: Where to place control valve on DB 995 in reply to James, 07-13-2002 17:19:18
Hi James Make up a pedestal to mount the valve on and mount it on with the loader frame. In the 4 bolt holes on the side just ahead of the foot throttle. You will have to use 6 to 8 feet of hose on each circuit to allow the loader to slide off. Then you can feed the hose on in and lay between the loader and hood. Even weld hooks to mount the hose onto. Did the power beyond get to you. I have a virus here and my email is not working properly.
James
07-13-2002 19:37:28
 Re: Re: Where to place control valve on DB 995 in reply to Elmer, 07-13-2002 18:07:53
There is an insured parcel at the post office for me. I hope that is the power beyond. I didn't get the mail today until 9pm. I wasn't really expecting it this early, seems like last time it took two weeks. If I remember correctly, it has only been a week this time.
I mounted the loader today using the remote. The previous owner had a tractor with two remotes, so all the hoses currently have quick couplers.
Elmer
07-14-2002 06:09:33
 Re: Re: Re: Where to place control valve on DB 995 in reply to James, 07-13-2002 19:37:28
Just mount couplers on the valve and use the existing hose. The hoses will allow the tractor to back away from the loader as you dismount it. I use coloured plastic tie straps to colour code the hoses to the cupler. If you can't find any let me know and i'll mail some to you. Nice part about having a quick tach loader is when you want to do field work you can drop the loader off. Easier on the front end in rough terrain.
