Head gasket for Case 500 Diesel
Kelly
07-11-2002 22:01:57
Looking for an outlet for a head gasket or set for my Case 500 Diesel.
RobertTX
07-12-2002 05:32:03
 Re: Head gasket for Case 500 Diesel in reply to Kelly, 07-11-2002 22:01:57
caseman-d has it exactly right. Two different heads, two different gasket sets. Find the casting number (which is also the part number) on the head under the valve cover. They are available from Case IH, you may need to help your parts guy with your parts book.
caseman-d
07-12-2002 05:02:08
Are you referring to the 377 6 cylinder diesel. I would try your old Case IH dealer. Case used two different head numbers so make sure you have the head numbers when ordering them. You have a choice between a 6320A (valve grind kit A20150) or A6320A (valve grind kit A20148). I would double check all 3 heads to make sure there the same.
caseman-d
