David Brown
smurph72
07-10-2002 12:57:00
A friend of mine has a David Brown that last ran about 2-3 years ago. The throttle stuck wide open last time it was running. It's a diesel.
He thinks the throttle linkage is just corroded. Any other things to check????
Thanks for any info, I usually hang out on the Farmall board but want to help him with his tractor.
dcm
Elmer
07-11-2002 02:46:11
 Re: David Brown in reply to smurph72, 07-10-2002 12:57:00
The only thing i can suggest is to disconnect the throttle linkage at the injection pump and see what happens. The linkage inside the pump may be stuck. I have never seen or heard of this happen before.
Tim Pennell
07-14-2002 23:00:51
 Re: Re: David Brown in reply to Elmer, 07-11-2002 02:46:11
I had one stick closed after sitting, so I would guess the thing could stick open.
Tim
