figure this out!?
jallread
03-10-2006 18:53:26
I just bought a 440 Case (late 60's). The hydraulic line from the pump to the control has had a valve spliced into it. The guy I bought it from says he doesn't know why but if you raise the 3pt with the original control, it blows the seal around the control piston so he just always used the valve that had been spliced into it. I am a big proponent of 'if it works go with it' but this setup seems pretty weak. Anyone got any ideas why this has been done?
Walt Davies
03-13-2006 11:53:04
 Re: figure this out!? in reply to jallread, 03-10-2006 18:53:26
Sounds like someone has raised the pump pressure by adjusting the relief valve. either that or the relief valve is bad. I would check the pressure to see if its correct then proceed from there. If you don't know about hydraulics then i would have someone who does look at it before you mess around and do some other damage. Walt
