Hi All,Haven't been out to my property to mow the place in about a month, so I figured this weekend was the weekend to get after it. Could NOT get the tractor to run. Had fresh gas, etc.- but it would just run a little bit and then die. When it wasn't running, small amounts of gas would pour out of the drain hole in the bottom of the carburetor bowl. I finally took the carb off and back apart (even though it should be crystal clean from all of my earlier rebuild work.) Not a speck of dirt in the needle seat, no gas in the floats, float height adjusted correctly... what to do? I finally just put it back on to tried again. This time- I couldn't even get the tractor to start, period. Finally, I looked at the spark end of the ignition equation. Hadn't thought of this earlier, as the magneto is newly rebuilt, as well. I had a really hard time getting the magneto cap to come off, and when it did... what a mess! Seems that a nest of really large carpenter ants had decided that the drain hole on the bottom of the H4's rotor cap was just perfect for them to use as a front door to a new nest. Needless to say, the spinning rotor made mush of lots of ants and ant eggs. It was really pretty gross in there. The ants had corroded the rotor contact pretty badly, as well. Well, I cleaned it all up, wire brushed the rotor, and it started right up! I guess the extra gas dripping from the bowl was just from my extended cranking of the engine, not from an improperly seated needle valve. This time, when I dissassembled the carburetor, I removed the main jet... something I'd never been able to get it out before. Looks like I affected something, though- because the tractor won't run under load now, despite the setting of the load screw. I guess this a problem for next weekend. Time to start in earnest on my "spare carb" project. Never did get any mowing done. It REALLY burns me that it would have run perfectly and been adjusted just right if I'd never fooled with the carb! Anyway- thought I'd share my "extermination" story with the group. Happy Tractoring! -Schotte
