Help with Old Case Plow??
Steve Mason
07-08-2002 06:38:31
Gentlemen, I bought and old 2 bottom Case plow this weekend for $100. I have no idea what I have here or how to operate it. Can you guys give me some idea how to go about identifying this plow? What I can tell you is that it is on steel wheels with the left wheel being larger than the right.
It is a pull type. It has a funny looking hitch on it that the guy I bought it from says drops into a clevis attached to the tractor draw bar. It has Case stamped on the top of the main frame members but I cannot find any numbers. The left wheel assembly has some kind of gear box looking thing on it. It has 2 lever arms that extend forward for raising the plow shares. What else can I tell you that will help identify this thing?
If I can this thing identified maybe I can find a manual somewhere that tells me how to maintain and use this thing. Thanks,
Steve
Butch/OH
07-08-2002 20:42:52
 Re: Help with Old Case Plow?? in reply to Steve Mason, 07-08-2002 06:38:31
If the plow has a tail wheel that goes up and down from linkage connected to the front wheels its probably a model B what they called the centenial plow. If the tail wheel is rigid it might be a model BL.I think both were made about the same time, mid 30's thru mid 50's.
Steve Mason
07-10-2002 05:59:47
 Re: Re: Help with Old Case Plow?? in reply to Butch/OH, 07-08-2002 20:42:52
Thanks Butch, that sure helps! It does have the tail whell assembly that lifts up and down. Any idea if manuals are still available for this plow?
Steve
