Eagel Hitch Problem 53 DC
Paul f
07-08-2002 06:16:47
My 53 DC with Live PTO and eagle hitch will not lift the rear wheel(s) of 3pt Ford brush hog or New Holland 3pt finish mower clear of the ground. The hydraulics work and the lift cylinder fully extends. Front end comes way up but not the back. The top link is mounted on top of the PTO Access plate (Uses two of the Case "Bracket, mounting , adjusting screw O9195AB". I have put tried adjusting the top link length and put 1 inch spacers between the PTO access plate and the brackets. No improvement. Any suggestions????
DKase
07-08-2002 21:22:49
 Re: Eagel Hitch Problem 53 DC in reply to Paul f, 07-08-2002 06:16:47
Once you get the top link high enough it will lift. Before you use it throw the top link in the shed and put a length of log chain in place of it. If you go through a dip with the arms down the tail wheel will not be able to go up and you will bend the tail wheel up. I know from experience!
Paul f
07-10-2002 05:35:47
 Re: Re: Eagel Hitch Problem 53 DC in reply to DKase, 07-08-2002 21:22:49
Thank you for teh hints. Any idea how high above the PTO cas I need to go???
Butch/ OH
07-08-2002 20:32:59
I know what you are talking about Paul. We have the same problem with our 400. If you could raise the point on the implement where the top link fastens so that it is at least as much higher than the two lower pins as the distance between the same links on the tractor. In other words make that A frame on the implement as high as the top link mount is above the lower link mounts. I have also seen a PTO sheild built out of 1/2 in. plate and having a set of ears on it stout enough to fasten the top link to.
