Traction problems for dc
steve
07-07-2002 19:25:41
I went to a tractor pull today, pulling in the 4500# class, this is the 2nd pull i've been to and both times i've spun out. I have 12-4 36 inch tires, would I be better off running a wider tire? and if so, how wide could I go and still use the same rims? my tires are about 90%
DKase
07-08-2002 21:35:16
 Re: traction problems for dc in reply to steve, 07-07-2002 19:25:41
I'm not sure this will help you, but I have a 54 DC-4 with 20.8x38's. I have the heart front end with the heavy wheels. I hang another 200# as far forward as I can. I run about 2# air. They make me run what they call the modified class even though my drivetrain is stock. I've never been beat. Sounds like you need your drawbar higher.
SEAMO
07-08-2002 08:13:28
STEVE,What type of tread? How tall are the bars? How wide are the rims? Did you raise the front when you spun out? How long is your drawbar? I don't have problem with 36in rubber if it is the right kind. What kind of track,clay, black dirt, soft,hard,What kind of tires won all the pulls. Not size but brand. 45deg? 23deg? there are alot of factors in getting your tractor to hook up.Earl in Illinois
pfrederi
07-08-2002 06:02:31
Steve: I was at a pull this weekend and one DC owner had replaced the cast front wheels with those from an SC to save weight... that might let you use bigger tires on the rear
Wolverine
07-07-2002 19:47:43
I assume you mean 38 inch rims on your DC. If not they should be. My buddy pulls a DC with 14.9/38 gets a good grip. But they aint cheap!
steve
07-07-2002 21:00:16
 Re: Re: traction problems for dc in reply to Wolverine, 07-07-2002 19:47:43
I had 13-6 38 inch tires with the cast iron hubs that put me over 5000#, the only way i could get into the 4500# class was to go with the steel wheels with the 34 inch rubber, which puts me at 4485#, I also run tire pressure at 12#?
CASEPOWER
07-08-2002 04:38:06
 Re: Re: Re: traction problems for dc in reply to steve, 07-07-2002 21:00:16
If you are pulling in a 4500 class and your tires are at 12#s you better drop down to at least 9# and maybe as low as 7# Also if your weight is not tranfering of the front you will have problems. Does the front come up? how high is your drawbar? It should be 20" and 18" back from center of axle if that is legal were you are pulling. If you are to heavy on the front you may have to add 500# AND pull 5000# or 1000# and pull 5500# class. CASEPOWER
joecool
07-08-2002 04:27:14
I pull a 51 dc, in 5500 I spin out, 6500 I spin out and have pulled at 7000 and spin out. I have new 13.6/38 firestone field and road, weights in front and behind rear axle as well as wheel weights. I haven't been able to get into 4500 but dad has a cc with dc guts in engine and pulls at 4500 and spins out and has no problem with power. Put on dyno or add weights.
ken c
07-08-2002 14:05:19
 Re: Re: Re: Re: traction problems for dc in reply to joecool, 07-08-2002 04:27:14
I pull my DC in the 6500# class with 14/9 38 firestone champion ground grip nearly worn out. and itdoesn't do bad , still have enough power to poull dead weight sled at idle doesn't do bad on tyransfer sled either. I have about 200# on the eagle hitch arms and have a extra set of hubs on the axle.(surprizes a lot of people) Hope you get it hooked up..they do a good job.. ken
