Oil leaks on 1950 dc case
steve
07-04-2002 18:10:50
i am having troubles with oil leaks, i've been using case ih hytran plus, do i need to be using a heavier lubricant or just start replacing seals?
S.A Beatty
07-06-2002 05:06:23
 Re: oil leaks on 1950 dc case in reply to steve, 07-04-2002 18:10:50
Steve,
I'm finishing up my VAC and I had the same problem. To save your self a lot of bad words, replace the seals. If they leak now they will leak forever.
Sam
Old Iron
07-04-2002 18:43:42
You should be using SAE 140 Transmission Lube in the tranmission and SAE 30 NON DETERGENT oil in the hydraulics.
Larry
07-04-2002 18:22:05
Where have you been useing the hytran? In the hydraulics? Since your DC doesn't have live PTO I think a heavier hydraulic fluid would work better. BTW, where are you leaks located?
steve
07-05-2002 14:47:47
 Re: Re: oil leaks on 1950 dc case in reply to Larry, 07-04-2002 18:22:05
i was told that the transmission and the rearend was all one compartment? if not where do i put in the transmission grease? my leaks are mainly around the belt pulley shaft, and the hand clutch shaft that goes through the tractor in front of the belt pully.
Larry
07-05-2002 18:39:10
 Re: Re: Re: oil leaks on 1950 dc case in reply to steve, 07-05-2002 14:47:47
Is that where you put the hytran? The rear end and tranny are one and the same,just like Old Iron Said.But the hydraulic is seperate from that. It's been a long time since I have fooled with a DC,but if I remember right the transmission grease goes in a large hole and the hydraulic oil goes in a smaller one. I think they are pretty close to each other. I hope this helps,or someone else will tell you what is correct.
Old Iron
07-05-2002 16:55:59
The transmission and rear end are all one. The fill plug is on top of the power take off box. There is a seal on the power take off shaft that is easy to replace. There are seals on both sides of the clutch shaft.
steve
07-05-2002 20:57:14
 Re: Re: Re: Re: oil leaks on 1950 dc case in reply to Old Iron, 07-05-2002 16:55:59
THANKS'YOU GUYS HAVE BEEN A BIG HELP TO SOMEONE WHO DOESN'T KNOW MUCH ABOUT A DC
