Need help locating piston seal for Case 641C eagle hitch...
John S
06-30-2002 19:47:51
I need a part number or current day cross-reference for the hydraulic piston oil seal used on the eagle 3-point hitch for my 641C. Rough dimensions are 3.25" ID and 3.75" OD. The only markings on the seal are "C8B". Also, does anyone know a Case dealer who sells parts for these older tractors in Oklahoma??? Thanks!
David
07-07-2002 12:10:13
 Re: Need help locating piston seal for Case 641C eagle hitch... in reply to John S, 06-30-2002 19:47:51
John, My tractor is a 641L, should be the same thing,I think in the kit there was a rubber o-ring and another round seal that was made out of something pretty stiff, it was about 3/4 inch wide ,I think I had to put it in very hot water to make it flexable so I could slip it over the shaft.The dealer number is 1-270-692-2169,Lawson Tractor Com. It is in K.Y.I hope this helps. David
John S
07-09-2002 19:29:03
 Re: Re: Need help locating piston seal for Case 641C eagle hitch... in reply to David, 07-07-2002 12:10:13
David, thanks for all the help. I've got the parts I need on order from a CASE dealer I found here in Oklahoma. Again, thanks for the assistance.
David
07-02-2002 19:58:12
John, I have a 641 myself, it is a great tractor, I put a seal kit in mine about two years ago. I got the parts from a local case-IH dealer, had to be ordered but only took a couple of days Let me know if the other reply dosnt have any luck.I'll see if I can still find them. David
John S
07-05-2002 18:37:25
 Re: Re: Need help locating piston seal for Case 641C eagle hitch... in reply to David, 07-02-2002 19:58:12
David, thanks for the feedback. I haven't heard back from JR yet, but I remain optimistic. You mentioned obtaining a "seal kit" for your 641. I was wondering, what could be included in a seal kit since there only seems to be one seal. If you have time, please let me know the seal kit part number or the name and number for your Case dealer so I can give them a call. Again, thanks for the responce.
J.R.
07-01-2002 18:04:09
Got you covered. I'll give this to the parts manager tomorrow morning. Case dealer since 1946. JR
John S
07-05-2002 18:26:08
 Re: Re: Need help locating piston seal for Case 641C eagle hitch... in reply to J.R., 07-01-2002 18:04:09
Thanks JR! Any luck with your parts manager regarding my 641C oil seal? I'd be glad to call the dealer myself if I only had a phone number. Again, thanks for any help you can provide.
J.R.
07-08-2002 17:44:05
 Re: Re: Re: Need help locating piston seal for Case 641C eagle hitch... in reply to John S, 07-05-2002 18:26:08
I found your seal for the hitch. It is $27.86 plus shipping. If you call Doug in parts @ 888-700-0807, he will order it and have it shipped direct to you so you only pay shipping once. JR
John S
07-09-2002 19:35:12
 Re: Re: Re: Re: Need help locating piston seal for Case 641C eagle hitch... in reply to J.R., 07-08-2002 17:44:05
J.R. I appreciate the lead on the part availablity in WI. I was able to order the part from a CASE dealer I found here in Oklahoma. I'll keep the phone number you gave me for future use. Again, thanks for the assistance.
