VAC Carb - Hole in bottom of TSX 114
Hank (MO)
03-10-2006 04:17:58
I've got a MS TSX 114 carb for my 1946 VAC that I'm currently re-building. I don't think it had ever been rebuilt before. It was very dirty inside, it leaked gas, and the engine was hard to start.
So I've got the carb apart, and I've got my basic rebuild kit. My question is that I've got a 1/8" hole in the bottom of the carb. I know for other MS carbs there is a hole in the bottom that is "plugged" with a scintered bronze plug. This allows gas to leak out, when the engine is not running, instead of accumulating. The scintered bronze acts as sort of an air filter when the engine is running. However, mine doesn't have one of these... it's just a 1/8" hole.
The rebuild kit did not contain a "plug" to put in there. Is this something I can buy elsewhere? Is it actually needed or not? Anybody know a part number?
Thanks for all help.
Glen in TX
03-10-2006 21:33:42
 Re: VAC Carb - Hole in bottom of TSX 114 in reply to Hank (MO), 03-10-2006 04:17:58
The MS number it 95-78 for that brass thing. You might try Case dealer or even JD dealer. JD parts shows to have it for $4.07 ! If you insist on having the brass piece also might try vepetersen.com , call them don't email or wait forever. What I have used and what they used on some carbs is a felt plug and washer instead of the wool packing. Wool packing will work also and better than nothing as that hole is your bowl vent.
Steve_Md
03-10-2006 05:15:40
I rebuilt the carb on my 47 VAC and it also has a thru hole with no cintered material. It appeared to have some steel wool in place. I used some brass wool and as I remember it also had a washer that was "staked in" to capture the wool.
F-I-T
03-10-2006 10:23:49
 Re: VAC Carb - Hole in bottom of TSX 114 in reply to Steve_Md, 03-10-2006 05:15:40
I have made them using an old GM in-line fuel filter for like a 327. It's the same cintered brass stuff. Just be careful not to smear the pores shut if you turn, machine, or grind it.
Frank
