Rhino Brush Hogs
Rick
06-27-2002 10:43:25
Since I own a Case and monitor this board, I'll just ask here-anyone know anything about Rhino brush hogs? Are they still in business? Hard/easy to get parts for, etc?
Found a 6' model for $450-looks pretty heavy duty. Thanks in advance,
Rick
Thad
06-28-2002 17:52:21
 Re: Rhino Brush Hogs in reply to Rick, 06-27-2002 10:43:25
Alamo owns Rhino and MW i know because i am a dealer for both and have sold tons of them. The Mw PC1530 was a good cutter but try to get a hub for a slip clutch cant do it have to convert it over only costs you350 to 400 last time i checked. A SE 15 4 Rhino is a better cutter it has 4 gear boxes and dual load carrying wheels if ordered. As far as decks they did have some trouble and i havent had any in years. Buy what best fits your application and good luck.
brian
06-28-2002 18:55:14
 Re: Re: Rhino Brush Hogs in reply to Thad, 06-28-2002 17:52:21
We got three of the pc1530's and we make our own hubs for $50. I'll agree that the hubs are a weak point if you don't keep them tight. The one I bought in 94' has mowed about 7,000 acres and has the original hubs on it. However we have had a tremendous amount of drivline problems out of the rhino. The front carrier bearing has givin us problems from day one. I also like the fact that the M&W is lighter in weight than the rhino. It is easier on drawbars.
brian in ky
Thad
06-29-2002 03:38:27
 Re: Re: Re: Rhino Brush Hogs in reply to brian, 06-28-2002 18:55:14
I have a customer who has a 1070 witha turbo on it he pulls a PC 1530. He has a 2100 acre ranch and has never had a gear box problem and that is amazing. I have had dozens of people tell me he gets the front of the tractor off the ground because he drives over stuff so big. Dont ask me about his deck and drivelines lots of welding rods. Hes tested one down in these hills and its done fine so its like i say buy what fits.
brian
06-29-2002 20:06:09
 Re: Re: Re: Re: Rhino Brush Hogs in reply to Thad, 06-29-2002 03:38:27
I've mowed locust trees that are 15' tall and almost as bid around as your leg with our older mower. It has a bout 20,000 acres on it. We let the bolts get loose that hold the front gear box to the deck. It cracked the deck so we built a plate to get it back running. It doesn't mow level because of the plate so we use it on our own farms cleaning up the rough stuff.
brian in ky
D Smoker
06-28-2002 16:40:08
I have to agree with Brian on this one. We have one at work and I'll be the first to say we're hard on brush hogs. But the same situation, we used it three months and had to reweld the entire mower. The gearbox seems to be taking it ok, but the welds just don't seem to stand up. We've had rocks punch holes through the deck, just seems the metal is too thin on the deck. I'd go to Woods or somebody else, but not a Rhino agian.
brian
06-28-2002 05:04:11
Rhino bought M&W and now build the Rhino mower under the M&W name. You can get parts for them. I don't know about their small mowers but about five years ago I bought a new batwing and it was a complete pile of junk. I had to go over and reweld 60% of the welds after using it one month mowing on horsefarms. It has never seen the rough ground that my Older M&W PC1530 has seen and never will. It is a heavier mower but weight is the only thing heavy duty about it.
brian in ky
