Swapping 188d for 207d need Flywheel
waynelman
06-27-2002 09:32:29
HI
I'm looking for a flywheel that will bolt to my case 207D
engine. I have a 480Ck loader hoe with a manual clutch.
the case part # is A135973 for the flywheel. the flywheel should have a good 135 tooth ring gear that measures 13 3/4 " across the outside tooth to tooth.
please send info to [email protected] , wood I be able to redrill my flywheel to fit the 207d crank? IT came with a hydro-st flywheel
