DC3 Belt Pulley Problem
Paul f
06-26-2002 05:59:49
The parts manual shows 8 rubber plugs that fit into grooves in the belt pulley and its hub. I do not have anything in mine at all. Is this the cause of the clanking noise that comes from the pulley??
Case dealer checked and the part number is no longer valid. O7644AB. Has any one come up wtih an alternative? I don't use the pulley but the clanking is not a good thing.
jal-SD
06-26-2002 06:54:06
 Re: DC3 Belt Pulley Problem in reply to Paul f, 06-26-2002 05:59:49
We don't have plugs on the pulley on one of our DC's, but ya gotta tighten it often. On the other one, we took the pulley off. Thought about cutting up a tire sidewall for plugs, but have never done it-looks like a lotta work. (My $0.02 worth. jal-SD)
RobertTX
06-26-2002 06:50:07
I believe 1/2" neoprene rope (or wire?) is the correct replacement. It is available from McMaster Carr. I haven't bought any yet, but have been told that is the right stuff.
Paul f
06-26-2002 10:00:45
 Re: Re: DC3 Belt Pulley Problem in reply to RobertTX, 06-26-2002 06:50:07
Thanks for the help. Turns out to be neoprene cord.(Often knowing what to call it is half the battle) Ordered some, I will let you know how it works.
Paul f
