SC Carb.
Steve
06-25-2002 19:36:55
My '42 SC idles too rich. I can get it leaned out somewhat if I back the idle adjust screw all of the way out. It even picks up a few RPM if I remove the screw completely! It seems to run the best about 4 or 5 turns out. Since this is well beyond the bench setting, I think something is wrong. I have taken the carb apart, and cleaned the ports with Gumout, but I am wondering if someone knows what I am missing.
Thanks for your help.
Mike Schotte
06-26-2002 13:18:52
 Re: SC Carb. in reply to Steve, 06-25-2002 19:36:55
I noticed the same thing when I rebuilt my carb (Zenith 9667A). The idle adjustment screw doesn't make a lick of difference... only the adjustment of the load screw (main jet adjustment assembly does.) I had to set it at about 4-1/2 turns out instead of the recommended 1-1/2 to 2-1/2. After that, it runs & works just fine.
I didn't have any problems with it running rich though. Although you will certainly have this problem if the floats are not adjusted right (believe me, I've been down that road!) Also, check the floats for any pinholes, as well.
Good luck- Let us know what you find out, and sorry I couldn't be more help.
Regards, -Schotte
Mike H.
06-28-2002 14:22:56
 Re: Re: SC Carb. in reply to Mike Schotte, 06-26-2002 13:18:52
Our SC (4602380SC) didn't run worth a darn after I rebuilt the carb. After taking it apart half a dozen times and making adjustments I finally cleaned up the original parts and put them back in it. It still didn't run too well so I changed to Autolite plugs that are hotter than the Champions I had in it. Now it runs like a champ. It must have been the plugs all along. Hope this helps.
Baggsy
06-26-2002 11:01:07
Is it a Zenith 9667? My idle screw doesn't make much difference at different settings, and it burned rich until I moved to a notch hotter plug (Autolite's). Are both mating surfaces from top and bottom sealing good? And is the carb/manifold gasket getting a good seal?
