970 Case
mike
06-25-2002 13:08:02
The parking brake light on my 970 does not lite when the parking brake is applied. Any suggestions on what's the problem or where I should begin looking. Thanks in advance.
mk
Don
06-25-2002 22:02:07
 Re: 970 Case in reply to mike, 06-25-2002 13:08:02
I would check with a test lite at the switch to see if you have power to the switch, then operate switch manually to see if it works. Your lite bulb could also be bad. Or you could ground the wire going to the switch to see if the lite works. Hope this helps.
