Rear axle removal
Ken
06-25-2002 05:56:53
Do I have to spit the tractor at rear-end and transisson to get the left axle out or can I get through the PTO case if I took that off. Book said, you have to split.I forgot to tell you guys on what kind of tractor. 1951 VAC Case
S.A. Beatty
07-06-2002 05:14:23
 Re: Rear axle removal in reply to Ken, 06-25-2002 05:56:53
Split the tractor and clean out the rearend you will be glad you did in the long run. Make sure you check every part inside the axle.
Sam
Max
06-25-2002 20:27:04
Work thru the top hitch cover, there's more room. Oh, no you don't have to split it just to remove the axle, it just makes sense to split it so that you can tear the transaxle completely apart to clean out the debris better.
