What's in a Case 1210 Serial Number?
Gator04
03-09-2006 17:58:14
What info (help) can I get as to year and HP from the following info of my David Brown Case 1210, 4cly D.:
S/N 1210/8/11160722
Stamped on the right side (sitting in seat) of engine is 455009 and stamped just under that and to the right slightly is 751856.
On The left side of the engine casted in is MG25389 and in behind the injector pump is EW 2 casted into the block. The head has a fancy CBS that has a circle around it.
Am going to try and post a picture in the photo area of this tear down I have going..... any info appreciated and trust me I will be back (nothing like practicing brain surgery on a live victim)..... ..... ..
Tom (Ks)
03-09-2006 19:03:30
 Re: What's in a Case 1210 Serial Number? in reply to Gator04, 03-09-2006 17:58:14
You have a 1978 tractor, 66 HP. Some numbers on the engine will be casting numbers, serial number of engine and block numbers. Sometimes there are three digit numbers the the company uses to identify their castings. I believe "CFW" stands for "Case foundry works", you will see things like that.
Gator04
03-10-2006 03:19:53
 Re: What's in a Case 1210 Serial Number? in reply to Tom (Ks), 03-09-2006 19:03:30
Thanks Tom - appreciate the information.
