NH 67 bailer shear pins
Mark
06-22-2002 20:15:46
Have a NH 67 bailer keeps using shear pins. loud noise when trips for new bail and shears pin every 3 bails
thanks
Mark
robert
06-22-2002 20:36:25
 Re: NH 67 bailer shear pins in reply to Mark, 06-22-2002 20:15:46
Could be many things.But I wonder if your needle yolk brake is too loose thus allowing your safty stop to engage plunger crank arm in front of plunger thus shearing bolts.which is better than having plunger waste needles!!!.See that brake on knotter shaft end is set up enough to hold needles and yolk tube steady until knotter trips to tie.If brake too loose what you describe will occur.Its been years since doing that stuff but it sure sounds familiar!!Roll over by hand very carefully and see that all is OK before powering up!!! Stay away from knotter when running,many fingers have been mashed off when knotter trips unexpectedly!Check knotter timing also!!
