VALVE CLEARANCE CASE 207
TIMJONES271
03-09-2006 17:30:44
DOES ANY BODY KNOW WHAT THE VALVE CLEARANCE IS ON A CASE 207 DIESEL ENGINE IT IS IN A 1845 UNILOADER, I WAS TOLD MY VALVES NEED ADJUSTING ON THIS FRESH REBUILT ENGINE, BECAUSE OF THE HEAVY FUEL SMOKE IT BLOWS OUT THE EXHAUST, I HAVE ONLY RAN THIS ENGINE FOR ABOUT TEN MINUTES, BEFORE I HAD THE ENGINE REBUILT, IT RAN FINE, UNTIL THE SEALS WENT OUT IN THE INJECTOR PUMP AND THE CRANKCASE FILLED WITH DIESEL AND WASHED OUT THE BEARINGS ANY HELP WOULD BE GREATLY APPRECIATED THANKS
Roger (Mi)
03-10-2006 04:58:00
 Re: Black smoke in reply to TIMJONES271, 03-09-2006 17:30:44
Why would someone go to the expense of an engine rebuild and not make sure that the valve clearances are correct? The 188 diesel is .014 for both intake and exhaust cold. The 159 gas is .012 intake and .014 exhaust cold.
While going to college, I worked for Case during the summers. One summer I had the pleasure of replacing the cylinder rods on brand new Case loader/backhoes. Some engineer lacking the intellegence of a fruit fly decided it would be economical to reduce the amount of chrome on those cylinder rods. Needless to say, they all pitted and rusted. While I was doing that, they wanted me to check valve clearances. You can believe it, I could chance cylinders rods and set valve clearances in my sleep.
Black smoke is a sign of incomplete combustion. Check the fuel injection pump timing and look for some faulty injectors.
Tom (Ks)
03-09-2006 19:07:47
 Re: VALVE CLEARANCE CASE 207 in reply to TIMJONES271, 03-09-2006 17:30:44
I agree with jdemaris on that one.
jdemaris
03-09-2006 18:02:35
Valve clearance for the 207D is .012" on the intake and .014" on the exhaust - both set cold. In regard to someone telling you improper clearance is causing the black smoking - I think they are telling you bullsh*t stories.
