David Brown 990 Implematic
Peter
06-20-2002 06:52:11
I finally figured out why the lift arms would not lower, they were locked into place. I pulled the large brass knob at the rear of the tractor and they went down. Is this normal for these tractors? Are the lift arms supposed to lock into place wren they are raised beyond a certain height? Elmer, if you are reading this I think you were right about the hydraulic pump. It is very weak and will only lift light implements. Even then at full throttle. I am interested in a new pump if you can get one for me. How hard are they to change?
Elmer
06-22-2002 05:41:13
 Re: David Brown 990 Implematic in reply to Peter, 06-20-2002 06:52:11
Hi Peter. There should be two pins behind the transport knob. The knob has two ramps cast into it, and when turned it pulls the pin out, allowing the hitch to drop. The transport assembly should remain disengaged. If not remove the snap ring and inspect the pins to see if they are still there. I am looking into a new pump for the implematic tractors. I may have a good used one coming in.
Peter
06-22-2002 20:46:33
 Re: Re: David Brown 990 Implematic in reply to Elmer, 06-22-2002 05:41:13
Elmer, I'll check the transport knob to see if the pins are in place. When turned it doesn't seem to do anything but it does release the lift arms when I pull it. Do you have any pins for sale if I need one? Also I am interested in a pump, I'll give you a call.
rod
06-21-2002 04:19:32
That is called transport mode on the David Brown. You should really get a owners manual to save yourself some headaches I don't know where I would be without the manuals. Elmer can supply them to.
regards
rod
rhudson i agree
06-21-2002 13:27:27
 Re: Re: David Brown 990 Implematic in reply to rod, 06-21-2002 04:19:32
would not want to learn about a david brown without the manual they're too "different"
the transport lock, cranking screw on the injector pump, various hydraulic handvalves and levers. i love the david brown's but they're different from john deeres we have around here.
