Case vac carb trouble
Tom Salliotte
06-19-2002 21:32:36
Can anyone tell me what settings the fuel and air screws should be at on a case vac carburetor ? It ran fine, but after running low on gas and sitting for a month, the carb won't pass any fuel to the intake. I took it apart, cleaned it up, re-assembled it, but still no fuel passage. Tractor runs as long as I spray starting fluid into choke opening. Any help out there ?
Tom
06-23-2002 10:03:33
 Re: case vac carb trouble in reply to Tom Salliotte, 06-19-2002 21:32:36
My Dad had three of the VA series tractors over the years(57-66). Two had Marvel-Schebler carbs and the other had a Zenith carb. As stated before check to see if you had the on/off valve under the tank open and that the sediment bowel is clean and the gas line to the carb is open and flowing well. I don't have a book on the carb settings but ensure that you don't have a blocked air filter/air supply. We always set the load screw(I don't remember how to tell you which is which since I haven't got one to walk you through) first by getting it to run and then put it on a pull to ajust the load screw back till you didn't see black smoke. Then you ajust the idle screw till the tractor idled smoothly. I hope that you can use this rule of thumb for ajusting the carb. Good luck.
Lew
06-20-2002 20:10:37
Is there fuel in the carb float bowl? If yes, check to see that you have the linkage connected correctly. How to check, you ask. Take out the small pipe drain plug in the bottom of the bowl and see if fuel runs out. If no fuel then look at the filter under the gas tank and see if the sediment bowl in full and also check if the fuel line petcock is open. If all these things fail to help, post again and I will check my VAC to see how many turns the screws are set at.
