Gas--is it hurting
Dutchman
03-09-2006 13:37:37
Hi, It's probly been asked before ...I just never seen it...QUESTION will...TODAYS GAS...hurt the tractor ??? today we have unleaded and ethenal blend....the OLD tractors they had LEADED.. Like before I THANK any and all ADVICE... THANKS.....MV
J. Wyssman
03-11-2006 12:36:04
 Re: Gas--is it hurting in reply to Dutchman, 03-09-2006 13:37:37
I've continued to add Marvel Mystery Oil to the fuel to my tractors. That's a '49 LA Case and a '47 Ford 2N. My Grandfather used it since the tractors were new and I find that it also extends the life of spark plugs too, especially if I use the higher octane fuel at the pump. The sheds where my Grandfather kept the tractors still have a few cans of the MM Oil sitting on the sill plates. Just follow the directions on the bottle for gasoline. I think it's about 4oz per 10 gal.
SO-Man
03-09-2006 19:28:30
When working on any old tractor i always install hardned valve seats. You can burn any gas and not worry about your valves.
Kris Golden
03-09-2006 15:49:28
I have heard from a reliable source that if an engine was run for several years with leaded gas, the lead deposits have embedded themselves in the metal [valves and valve seats] through the extreme temperatures and pressures of a running engine, and runing them on lead free gas will do no harm to them. I just wonder if doing a valve job grinds away all the protection?
Bob Soma
03-09-2006 15:11:23
Lead additive is available at most gas stations / farm parts outlets. I think it's well worth using it.
dctom
03-09-2006 15:04:31
ADD A LITTLE TWO-CYCLE OIL TO EACH TANK OF GAS FOR UPER CYLINDER LUBE AND YOU WILL HAVE NO PROBLEM AT ALL
Dutchman
03-09-2006 16:27:59
 Re: Gas--is it hurting in reply to dctom, 03-09-2006 15:04:31
Tom, Was wondering what kind of RATIO are you talking ?? say for a 5 gal ... THANKS.....MV
dctom
03-10-2006 05:28:22
 Re: Gas--is it hurting in reply to Dutchman, 03-09-2006 16:27:59
about the same ratio as for your chain saw, i use two little bottles for a tank full about 18 gal, tom
Steve Miller
03-09-2006 16:01:53
So, for a 22-gal tank how much oil would you recommend?
