Don't do this
jim handke
03-09-2006 06:19:46
Two years ago I put a rear axle bushing and seal in my 2470. Since the yoke had a bad groove where the seal rubs, I installed a speedi-sleeve from NAPA. Do not do this, even if I bragged it up back then. I"m replacing everything again today. The problem is you have to drive the bushing farther into the axle housing to keep the speedi-sleeve from pinching into the bushing and binding everything up. This must let the yoke wobble a little at the u-joint end, wearing both the seal and bushing very quickly. I apologize to anyone who used this method and will have to repair his tractor again.
4435
03-11-2006 10:05:38
 Re: Don't do this in reply to jim handke, 03-09-2006 06:19:46
Thanks Jim. I will keep this in mind should I have the same dilema with my 4490. Actually my Case dealer said to not mess with the bushing unless unless it was physically damaged.
