Relief valve
Roger
06-07-2002 20:09:48
where is the relief valve on the hydraulic pump on a 1966 case 430. Is there a way to adjust the pressure. 3 point will lift 3000#+ loader weak someone said could be relief valve.
Zach
06-10-2002 08:14:00
 Re: relief valve in reply to Roger, 06-07-2002 20:09:48
its all up under the gas tank is where all the hyd. valves and suff is sooooo you might want to check there.
