I Need A fuel Tank for an 885 DB/Case diesel
Eddie in Ky
05-27-2002 18:44:44
I am getting rust in my fuel lines and keep stopping up the system. I am through putting up with this. Does anyone know of a place where I can get a new fuel tank for this thing. Any help will be greatly appreciated.Its a diesel David Brown/Case 885
Randy
06-10-2002 10:41:08
 Re: I Need A fuel Tank for an 885 DB/Case diesel in reply to Eddie in Ky, 05-27-2002 18:44:44
I cleaned a rather rusty A-C tank by (1) completely strip fittings, etc., off;(2) Fill with hot water and put a couple of cans of lye inside and let it sit a couple of days (do not do this if there is any aluminum anywhere on the tank!). This got the inside shiny-clean. I then used gas-tank sealer (as recommended above). Additionally, I had to fiberglass the bottom of my tank due to millions of rust pinholes. Tank has been in service for 10 years now with no problems.
rod
05-30-2002 03:50:36
I just relined two tanks one on my Ferguson other on my diesel DB 990 with Por 15 www.por15store.com tank sealer it seems to work fine and has stopped the rust problem so far much cheaper than a new tank.
regards
rod
