Ugly day
please advise
Ron
05-25-2002 17:08:47
Brought (drove) the mighty 1030 diesel home today and got to looking real close - ouch!!!
Here's the problems:
I noticed oil leaking (bubbling) from the corners of where the head meets the block. I assume this means blown head gasket. I also assume their is no re-torquing of the head bolts so I am looking at replacement. Am i correct? How much would you guess this will set me back?
The three point hitch went up as soon as it started and will not come down. Any ideas??
This has'nt been a good one!!!!! !!!!! !!
darBy
05-26-2002 22:47:21
 Re: ugly day - please advise in reply to Ron, 05-25-2002 17:08:47
On the three point hitch problem, check the valve under the platform. There is a spring that pulls the control spool forward to lower the three point. If the spring is broken or disconnected the arms will raise and not lower.
bob
05-26-2002 08:41:55
Ron THe oil leak off under the heads is no problem. I t is due to the fact as how close the oil passages is to the edge of the block head area and the type of gasket material allows tehm to leak oil after a few yrs. And trying to retorque the bolts you could break one off. W e run a bunch of 30 series monsters and it is very common to leak from the area. I also do lots of engine work to them so if you have more engine questions just email me.
Bob
