Yo, Jonathan......
Greg
05-23-2002 17:24:44
Thanks for the reply on the D Series Connecting rod.
I have lots of slide forward to back on the crankshaft yet NO up and down play..... It's funny how the front two rods appear to have NO play in any direction....
Is there anyway you know of to check the pins from below other than pulling them? I haven't been able
to twist the rods at all.
If I do pull the head and pistons, what should I be looking for?
Please remember that I am a greenhorn novice at engine work. I am patient and am good at clock repair. The only thing I got going for me with this is a good service manual, the ability to read,and you guys to guide me.
I don't want to pull the head until I am dead sure of the problem ( don't want to mess with the head
gasket). AT some point I want to do a complete engine overhaul but I would prefer a "quicker", less expensive way now( and so would my wife).
Thanks again...
Greg in Canada
craig
05-24-2002 19:32:02
 Re: Re: Yo, Jonathan...... in reply to Jonathan, 05-23-2002 20:48:51
I had to replace a rod in a dc last summer, not a big deal if you pull the piston all the way out(or at least it wasn't on mine) the bottom of the sleeve is flared just enuff that if you are carefull, you can squeeze the rings together with your hands and ease them back up in the hole without a ringcompressor. you could probably re ring the engine in about 45 mins. without taking the head off. Good luck..
