case 440 hydraulics
jallread
03-04-2006 14:42:21
Looking at a case 440 (late 1960'). It runs real well but when I try to raise the 3pt it spews hydraulic fluid from the piston located under the right side of the seat. The seal in that piston was recently replaced but that apparently didn't fix the problem. It acts as if the system is building to much pressure, is that possible and why? Any advice is appreciated
Mathias NY
03-06-2006 18:43:14
 Re: case 440 hydraulics in reply to jallread, 03-06-2006 16:31:31
I don't have any experience with you particular hydraulic system, so I can't really offer much help on how to fix it.
With that said, it sounds like you may have a couple of problems. The leak on the cylinder should be just as you thought, independent of the other problem. Some styles of cylinder have a gland on the rod end that can be tightened. If it is too loose the seal won't have have enough contact force to work properly. Air would not by itself cause a failure. Many seals won't contain air and allow it leak past, oil however would not. Air is a gas and is compressable. If it were trapped in the cylinder it would be more 'bouncy' and could see higher pressure in that condition. A high enough pressure blow the seal. Without seeing the style of cylinder I would suspect it was a loose gland or the seal was knicked on install
The raise/lower with engine rpm sounds like a more serious problem with the hydraulic system. It sounds like a seal or valve may be bad within the pump. At a higher rpm, higher flow is available to overcome internal leakage and build higher pressure causing the 3pt hitch to go to the setpoint it was trying to reach. When the rpm goes back down, the pump cannot overcome the leakage and it sinks back down. This could also happen with leakage inside the cylinder. A system low on fluid would exhibit similar symptoms.
For testing, I would check the fluid level, make sure it's full. I would try raising the lift all the way up, preferably with a load if the system will tolerate it, then shut the tractor off. If the lift drops quickly the problem is probably with the cylinder or the valve and not the pump.
I hope this helps some. Someone with more experience with the actual hydraulic system might be able to give you some better advice. Good luck.
