Help, cracked block! Case 300
Jeff King
04-21-2002 20:20:15
Finally got around to pulling down my G-310W to change out with an remanufactured head what I thought was bad valves. Found the webs between cyls 1&2, & 2&3 cracked, & the head gasket obvously leaking by between #s 2 & 3. Anyone with usable block or leads to one, please e-mail.
Thanks.
Jeff
Jeff King
04-22-2002 19:56:21
 Re: Re: Help, cracked block! Case 300 in reply to Mike, 04-22-2002 05:21:44
Thanks guys, I'll go out and get some #s off of the block and will be calling. From what I found, I suspect there is not much wrong with the head that came off of the engine. So I now have the take off head that is probably rebuildable. Will pull it down and take over the the machine shop for hot tank and magnaflux. If good, it will be available for sale.
