What diesel engine is in my 680ck-B? some rebuild questions
Can anyone tell me what diesel engine is in my 1970 680CK-B? Its a 4 cylinder diesel that I expect to have to do at least a rering on soon. I have built plenty of gas engines but never touched a diesel. Do these engines have removable sleeves, or do you have to pull the block to get it overbored? Is it possible to hone the cylinders and just put in new rings? If it has sleeves, do they just pull out are they a press fit or bolt in? Lastly, how do you check the compression of each cylinder on a diesel? Would the compression guage go in the injector hole? Sorry for so many questions but I am totally new to diesels.
Max
04-21-2002 19:45:54
 Re: Re: Re: what diesel engine is in my 680ck-B? some rebuild questions in reply to Dave.......thanks, few more questions, 04-21-2002 08:35:32
The sleeves come straight out the top, some like to use jacks, pullers, but my choice is a 2" round piece of T6 aluminum with a 4 lb hammer for persuasion. I would troubleshoot it a little more before tearing into it, might save yo a few bucks. It been a few years since I worked on one of those beasts but I think those engines even had the power cell on them. There should be someone here on the board that can help you fix those if that is the case.
