Flambeau red paint mixing
Greg
04-07-2002 11:41:11
Greetings
I'm getting ready to paint the rough surfaces of iron on a 1949 case DC-4... I'v been reviewing this site and some mention adding hardener to the paint...some suggest urethane.
I would like to know the ratio for mixing paint to hardener.
Also, I plan to do some of this rough painting with my 4 year old daughter by hand/paintbrush ( wheels, weights, transmission, etc.. Is it still adviseable to add hardener?
Thanks in advance.
Greg
Allan
04-07-2002 13:46:23
 Re: Flambeau red paint mixing in reply to Greg, 04-07-2002 11:41:11
This all depends on the type of paint you are using. Automotive enamel should be sprayed and should use the hardner as it speeds hardening, and makes it glossy. Acrylic enamel is all I've seen the flambeau red formula in. If you can get it in urethane then you have a choice. Urethane hardner is part of the paint process. It is a 2 part paint and must be mixed to work. I don't know how this would work brushed but i think it would not be good as it drys too fast. Remember that any of these automotive paints are harmful to breathe and a respirator is mandatory if you are working indoors, and should be used outside too.
