VAC belt pulley with a hydralic pump?
Dave
04-04-2002 21:00:38
I have a 1950 VAC and over the years have misplaced my belt pulley. I ran an ad requesting one and a guy called me with one that includes a hydralic pump. Mine didn't have a pump. Was this an option in 1950? Are they common? I have never seen one in a picture or in real life. He wanted $200.00 plus shipping for it.
Any thoughts?
ahj_wi
04-06-2002 06:19:22
 Re: VAC belt pulley with a hydralic pump? in reply to Dave, 04-04-2002 21:00:38
I saw a VAC sell at an auction last Saturday near Appleton, WI. that had the mid mount pump and no eagle hitch. It went for $475. I bought the 2 bottom plow and 7' mounted sickle mower that went with it, but not the tractor. Now, I'm trying to figure out how I'm going to mount this plow on my VAC with the Eagle hitch. I'm going to have to fabricate something. I might be willing to part with the sickle mower if anybody is interested.
A real nice VAC-14 with eagle hitch went for $1400. 3-14 plow with guage wheel went for $180(cheap). 4-16 semi-mounted plow went for $150. 12' disc with notched coulters on the front went for $525. All were excellent Case pieces.
Al in Wisconsin
wheat straw
04-06-2002 09:24:21
 Re: Re: VAC belt pulley with a hydralic pump? in reply to ahj_wi, 04-06-2002 06:19:22
ahj
A cousin had a vcmb mounted plow on his 8n ford. He bolted a pin through the hole on the mount bracket and bolted a home made mast to it for the top link. The only problem you may have is that the eagle hitch may not lower far enough for this to work. See if you can turn the mounting brackets up instead of down. This might be to much of a change. You might need to make a new bracket that has a hole at the proper hiegth. I hope it works. That is a keen little plow.
have fun.
Wheat Straw
VAC nut
04-04-2002 21:29:37
Older, pre-eagle hitch vac's used a mid mounted pump to raise and lower implements. Not really rare. All you want is the pulley itself, shouldn't run you more than $35-40 plus ship.
