DC won't run without clutch
Trevor T
04-04-2002 15:36:13
I bought a Case DC-4 1952, I know nothing about tractors but I seem to be having a fuel problem. The tractor won"t stay running without the choke, and I've had the carb apart and it looks to have a new needle and seat and there was no dirt in it or anything. There is a shut-off above the sediment bowl and I've noticed a air space on the top of the sediment bowl. The fuel drips out of the tank and I was thinking maybe it should flow to keep that sediment bowl full and maybe i'm sucking air. Would appreciate any advice for a beginner
Don R
04-07-2002 10:24:32
 Re: Re: Re: DC won't run without clutch in reply to Trevor T, 04-05-2002 15:55:47
Trevor,
The fuel should run out in two streams similar to an upside down V shape. If it isn't you are starving the engine for fuel. The problem is either in the sediment bowl assembly or you have debris in your tank. I bought an old DC that had sticks of every description in the tank. I think the old gentleman who owned it used the to check the gas with them but some were too short and fell out of his fingers.
