DC case starts by pulling not by starter
jeff
03-29-2002 09:42:13
I just recently bought a DC and it runs good if you pull start it but it won't start with the starter it sort of seems like the spark is week. when I'm useing the starter am I some how robbing juice fromthe mag which is causing a weaker spark or what? I have never tinkered with a mag of this sort.
Klyde
03-29-2002 10:01:56
 Re: DC case starts by pulling not by starter in reply to jeff, 03-29-2002 09:42:13
listen to the mag while you crank it over with the starter and see if you can hear the impulse coupling clicking. if you dont thats why it will start towing it. witout the impulse working you would have to crank it about twice as fast to get spark. it not only retards the spark, it makes the rotor spin faster, making a hotter spark at low rpm.
caseman-d
03-29-2002 09:54:25
Is there a possibility you have low compression. We had a 8N ford that we could crank all day on, but pull it ten feet and it would start.
caseman-d
