Tie-rod end grease seals?
Rick from Paso
03-25-2002 21:43:04
Anyone know where I could get a pair of tie-rod end grease seals for my Case 310B, it's a utility non-adjustable front end. It's also missing a thrust bearing on the left side steering knuckle. Thanks for any help.
Dennis/Ohio
03-28-2002 02:39:46
 Re: Tie-rod end grease seals? in reply to Rick from Paso, 03-25-2002 21:43:04
Hi, Case Dealer will have the steering items. The only part you may want thats expensive is the king pins. This is where having a parts manual usually helps. Dealer usually has trouble on the older parts look up. Best wishes, Dennis....
