VAC Oil Filter ???
Eric Foster
03-13-2002 08:41:06
Well, I broke the stem. I went to the local Case guru to get some help. He gave me the entire piece that bolts to the block (with a stem). However, I don't think it came from a VAC. There's a ball and spring type regulator that builds up pressure before dumping the oil back to the reservoir. What model is this from, and can I use it on my VAC?
Thanks
Eric Foster
03-14-2002 06:33:04
 Re: Re: VAC Oil Filter ??? in reply to Joe (Wa), 03-13-2002 18:22:13
Thanks Joe. I'll check for flow (I need to re-adjust the valve clearance anyhow). I'm hoping that there wasn't any permanent damage done to the cam bearings. This whole project started when my camshaft broke off at the timing gear. This thing might wind up becoming my parts tractor.
