Transmission fluid in 940-LP Wheatlant
Colt in Missour
03-11-2002 16:55:42
I need some help in locating the transmission and differential fill and check locations on my 940 LP. They are not where the owners manual suggests. The manual indicates they share a common fluid, light weight oil, but the fill ports are not as indicated directly in front of the PTO on the left or clutch side of the tractor. I am to the point of pulling a bolt in line with the assummed fluid level to verify and refill. I hope someone has a better suggestion. Thanks in advance for any ideas.
Jim P
03-11-2002 22:31:48
 Re: Transmission fluid in 940-LP Wheatlant in reply to Colt in Missouri, 03-11-2002 16:55:42
Is this a six speed or eight speed. On the six speed the ck. level is a square 1/4 in plug on the right side of the tran.cover about midway on axle level , if a low platform (get aboard from rear) model it is right at platform level. I have a 1966 CK western special six speed. I changed the oil from type A auto trans oil to to 90w. hypoid. Have run it six thousand hr. this way and no problems
