800 rocker arms
comfortking
02-26-2006 18:41:15
I need some help. I took the heads off of an 800 diesel to rework them and also pulled the sleeves to replace the O-rings. I started the tractor and it runs fine and the oil pressure gauge shows 30 lbs of pressure. Now the question. How much oil should be dripping from the rocker arms? I have very little. I replaced the o-rings on the tube that feeds the rocker arms. I removed the tube and there is not much oil coming from the oil passage in the head. I know I put the head gasket on right. Any ideas?
