IT RUNS!!!
segrat1
02-26-2006 08:15:47
Well I finally started up the 730 Case o Matic. When I started working on it this fall the cylinders were full of anti-freeze and a dozen other things were wrong. I found a set of heads here on the forum (mine were both cracked)then had all new valves,seats and springs installed. Replaced two of the pistons(bad ring grooves and one partially melted piston). New rings. Replaced all the fluids (hydro and trans oil looks like it came straight from a gernsey cow). New filters all the way around. I found a pin and part of a broken link from the PTO laying in the bottom of the PTO housing that must of been replaced by someone and they did not remember to pick it up (laying next to filter). The motor turned over about 5 or 6 times and fired up. No smoke from stack or breather tube. A short time later after adjusting the valves a little it was purring like a kitten. I opened the garage doors (after catching one of the grand kids boots in the back from wifey) and left the old girl (tractor) warm up to operating temp. After re-torquing the heads, installing new points and plugs and a final adjusting of the valves I started her up and took her for a spin down the road. Boy the snow machine tourists could not beleive it. I couldn"t go to far cause we have about 4 feet of snow and it"s only 10 degrees out but what a blast. Only thing left now is to check the pressures and find some info about the three point system on her. It"s not the same as the 3 point on my 504 International. Also have to find a leveling link assembly for the right side. Someone welded this one up. Can anyone point me in the right direction to learn more about the Case o Matic and the proper way to use it. Its a little different than the torgue amplifier on my 504.
Herrmann
02-27-2006 13:31:22
 Re: IT RUNS!!! in reply to segrat1, 02-26-2006 08:15:47
As far as manuals go, I"ve had good luck at tractor shows and swap meets. I got an original Case operators maual for $15, a original parts catalog for $20 and an original shop manual for $50. The operators manual will tell you almost evertything you need to know on how to operate and take care of the case-o-matic, as well as the rest of the tractor. The parts manual is nice in that it gives exploded views of eveything, part numbers and often times the size of a part. The shop manual is way better than a I&T shop manual. It has really nice charts of the case-omatic in color, shows precisely how it works, and how to fix it. I can"t remember all of the fellows I dealt with, but one was Jerry Erikson, he gave me his phone number it was 507-325-4745. Hope this helps.
John Saeli
02-26-2006 10:45:01
You touched a soft spot when you said you re-torqed them heads. As for usin the C-O-M, after you choose the gear, let the clutch out at idle. Don't try to slip it. Just let it out. Then throttle up. You get rolling, back of the throttle some & a quick flick of the lever will put you in direct drive. I might have that link, but a part # or pic would help.
Good luck!!
