case 300 powersteering part #
vac54
02-25-2006 07:52:05
case300 model 310 ser.6050900 powersteering pump any one have good luck fixing these. part number is G45157 gear drive. bolts on with 3 bolts. its called pump and reservoir. its for 134 power steering attachment,general purpose tractors. fix or buy good pump any one. or should i just part this old thing out. thanks.
Camboted
02-26-2006 01:11:39
 Re: case 300 powersteering part # in reply to vac54, 02-25-2006 07:52:05
I am not familiar with the gear drive pump. The model I have seen has a belt drive pump. If there is oil in the pump, and you have not run it dry, chances are you can fix it. Pull it apart, see what's wrong, and go to a good auto parts store. You have little to loose. If the gears are shot it's junk anyway. Are you sure the problem is the pump? Do you have the add on Char Lyn torque booster or a front mounted cylinder?
