Maximum compression for DC CASE
Merl
02-07-2002 16:05:07
can someone tell me what the maximum comp ratio I should go with for a pulling Tractor
laipuller
02-07-2002 22:17:16
 Re: Maximum compression for DC CASE in reply to Merl, 02-07-2002 16:05:07
this all depends on what you want the tractor to do, and how much you want to spend on fuel..I have a d that has 125psi of compression and does good on pump gas with an additive, or 104 or 110 octane racing fuel my other tractor has way more compression than that and run noting less than 114.it all depends on how much you want to try to get out of it without extensive machine work and specialty parts.. once again when it comes to tractor pulling the sky is the limit as long as the pocket book don't stop you
