Stuck pistons
WI farmboy
01-29-2002 09:54:35
I have a problem. The DC-4 has two stuck pistons. I have been able to remove one of the 4 the second is loose but I can't remove one of the bolts to the rod bearing because of where the stroke stopped. The other two that are stuck I can't move. The rod bearings are removed. I have been soaking them for a while with PB Blaster (worked great on the other stuff). If i could loosen the pistons I could advance the stroke so I could pull them out. Any Ideas on loosening these up?
Take a look over....
01-29-2002 15:11:42
 Re: Stuck pistons in reply to WI farmboy, 01-29-2002 09:54:35
...on the Farmall-IH board. There's a discussion under the posting "Farmall M" on 1/28 that has some do's & don'ts for getting stuck pistons out. BE PATIENT, they will come, but it'll take some work & time. Don't be afraid to look @ the IH board-those guys are good guys too & remember that even though it may have been a shotgun wedding, Case & IH ARE married! (My $0.02 worth. jal-SD)
WI farmboy
01-30-2002 05:33:34
 Re: Re: Stuck pistons in reply to Take a look over...., 01-29-2002 15:11:42
you need to add new holland to the shot gun marriage.
