David Brown 1210 - Hyd. Pump
Gator04
09-22-2006 09:51:18
My front mount double Hyd. pump has two steel pressure lines of which the steel lines are "sweat" fit into the fitting that bolts to the pump - both have let go once and one of them let go again (I brazed in last time) - I would love to find a bolt on fitting to convert over to rubber hose in lieu of the brazing or soldering of the lines again. Is there a readily availalbe fitting to do this? Much appreciated, thanks.
Gator04
09-25-2006 09:34:36
 Re: David Brown 1210 - Hyd. Pump in reply to Gator04, 09-22-2006 09:51:18
Well - being we have a machine shop where I work, a friend is going to re-invent the wheel and make just such an adapter. From there I can get the hoses made up and rid-myself of a headache - thanks.
richard in nz
09-22-2006 20:36:57
The bolt up ports on those pumps do have a "standard" but I can"t tell you what it is. If you go to a good place that deals in hydraulic pumps and the like they should be able to fit you up with an adaptor out to a threaded port to fit to a hose adaptor.
