Help identifying Case
Ron
01-26-2002 18:39:13
Need help identifying an old Case tricycle front end tractor. I think it's a VAC but I'm not sure. It has a 3 pt hitch with fast hitch ends on the lift arms. The tractor is a 4 cyl gas engine. 4 speed tranny with 1 & 2 foreward and 3 & 4 backward. The side of the engine has VT340 on the driver's side. Any help will be appreciated. My father in law just drug this one home and needs a little info before he starts working on it. He has restored 2 Farmall H's but this is his first Case restoration so we would appreciate anything anybody knows about it
Steve in MN
01-27-2002 19:18:33
 Re: Help identifying Case in reply to Ron, 01-26-2002 18:39:13
This is out of my JI Case Shop Manual for models C,D,L,LA,R,S,V,VA. (manual C-201 still available from Case or I&T--great book-also covers 200-800)
'Serial number located on instrument panel name plate. On all series except V & VA, engine serial number is stamped on left rear side of engine block in vicinity of air cleaner. On series V and VA, engine serial number is stamped on right side of engine block.'
This would include VC,VO,VAC,VAO,VAH according to the book.
My LA SN is stamped into the flange where the engine & transmission bolt together on left side near air cleaner. Hope this helps.
Ron
01-27-2002 18:48:00
 Re: Re: Help identifying Case in reply to Clint, 01-26-2002 22:02:42
Thanks for the help. Evidently all of the original tags were eaten by the cows. This is the only number we can read. There is another number inder the gauge panel that starts with vt but the numbers are unreadable
