DB990
Mark
01-21-2002 13:28:19
I have a DB990A selectomatic. This past summer my father in law used it to plow his field with. A couple of times while using it, it would just stall and not start again. It would fire on starting fluid but not stay running. So I went up, checked the filters, bled everything and it ran fine again, until once again this past summer when I was using it. I did the same thing again and it was ok after that. After this I replaced the fuel filters. Yesterday I was plowing snow with it and it did the same thing. At first I thought something was frozen, because it was only 3 degrees outside. Everything seemed fine, bled the system again, gave it a shot of starting fluid, and it started right up. Does anybody know what might be causing this? Thanks.
Elmer
01-22-2002 05:07:56
 Re: DB990 in reply to Mark, 01-21-2002 13:28:19
Saw the same thing happen before. Found a June Bug in the fuel tank. When ever the fuel level got low it would be sucked up against the suction tube in the tank. Once the tractor quit, it releived the low pressure and the june bug would float away from the line. It could be anything in the tank. But first look at the pump pin that is more common on high hour DB tractors. Also check the gasket on the pump for the sediment bowl. If you see air bubbles floating to the top of the bowl change the gasket.
