Case VA tractor info needed
Mathew Pierce
01-21-2002 12:16:01
Hi all,
I have a possible line on a 1954 Case VA tractor that has been sitting for 4 years. It is sitting because the ignition switch went out and the owner needed a frontend-loader tractor so he purchased a new Rhino to fit his needs. The only other known problem with the Case is that one of the rear wheel rims is rusting out on the bead and occasionally squirts the calcium mixture out when running over things like rocks. I've located a good used rim for $75 so that doesn't sound too bad to get fixed (does anyone know an average price to change a tractor tire?).
The asking price for this thing is $1200, from the , albiet minimal, description I gave, does the $1200 sound like something to pursue or do you think I should look elsewhere?
Thanks,
Mathew Pierce
Keith Hart
08-17-2002 21:43:41
 Re: Re: Case VA tractor info needed in reply to Les...fortunate, 01-21-2002 14:06:36
If you are interested in buying a 1949 VA fully restored, new tires battery, starter generator, wiring and paint runs excellant contact me we can talk price.
