Greetings to one and all. The best of the new year. Finally getting back to resolving a problem with a knock on a Case DC-4 engine.After removing the spark plug wire from #3 cylinder, the knock got VERY quiet. Based on what I have read in the postings, I am assuming that there is wear on the the upper bearing of that connecting rod.I recently had the lower bearings adjusted and they were fine. I am getting ready to order a rebabbitted rod and new piston pin( hopefully from Don L.). I have read and re-read the service manual ; however, since I am VERY NEW to engine work of this type, I can't help thinking ..."Is this all there is to it?" Specifically: 1) Does anything have to be done to a rebabbitted rod and new piston pin before re-installing it? 2) Can you really accomplish this task through the access ports in the oil pan? Or is it better to remove the oil pan? If so, what does one do with the front axle supports that appear attatched to the pan? 3) Do I need a ring compressor for dismantling or rebuilding( I plan to use the same set currenting in place as the compression is good). 4) Is there anything else I've overlooked in the diagnosis, the take down, and replacement of the part? Your thoughts/advice would go a long way to boosting my confidence in this matter. Thanks. Greg.
