I.D. 540
Kevin
01-18-2002 12:46:34
Couple of questions. My father just bought a Case 540. What are the differences between models, ie 540c, 540 AG, etc. Where is the serial number located. We can't find a data plate anywhere. Any help. Any key features that could I.D. the tractor further.
Kevin
01-19-2002 11:20:43
 Re: I.D. 540 in reply to Kevin, 01-18-2002 12:46:34
Thinking about it a little more I was thinking it could be a 540 c/k because it has a large hydraulic cylinder like it was a backhoe at some point in time.
Kevin
Dennis/Ohio
01-19-2002 03:39:50
Hello, Tag is on right side of dash panel or you'll see the 2 rivet holes that originally secured it. 540 is gas Utility, 540C is same with case-O-matic. 541 is gas general purpose (adjustable wide front axle optional). 541C same with case-O-matic. Utility: is lower to ground and has heavy duty wide front axle. Also I think the actual model # will be 540H because utility always came with High Speed 4th gear (highway gear). Best wishes, Dennis.....
